Directional scanner antenna?
MAguln8839
MEDWAY
Wilson Electronics Wideband Directional antenna 700-2400mhz 50ohm
Does anyone know if this type of antenna will work with a scanner on 700 and 800 MHz systems?
iMONITOR
Silent Key
S.E. Michigan
That should work fine! Inside it looks similar to this, maybe with more elements depending on the gain or bandwidth. That has a female Type-N connector that will require a male connector like this: (not a PL-259)
Yes. That's a Log Periodic antenna inside there. A bit different than a Yagi.
Wilson doesn't sell outstanding antennas. That'll work, but don't expect it to last forever. Then again, for the price you could buy a spare.
I put one of those up at my brother in laws place to connect a Cradlepoint type device to a cell site a few miles away. Works fine, but we put it under the eaves to keep it protected.
If 700/800MHz is all you are interested in, you'll get better performance out of a Yagi designed for those frequencies.
But, yes, it'll work.
merlin
DN32su
That is what it is made for but you can do better with a 5 to 9 element yagi.
The innards are nothing more than a phased array of log periodic dipoles etched on a PC board.
Point of that is for the bandwidth.
The Yagi can do 700 and 800 MHZ with more gain yet.
