Disable constant flashing red LED on XPR7580e
pdtek
We are about to deploy several hundred XPR7580e portables on a Mototurbo capable Tier 3 Cap Max system and the constant flashing red LED in standby is my big complaint. I have searched the settings in Radio Management /Configuration and found no way to stop it. Am I missing something? Also I found that if one of the front panel programmed buttons is set to Zone select, you loose that function if the direct channel entry from the keypad is enabled. Any help on that would also be appreciated. We bought these radios through our non-Motorola infrastructure supplier, so Motorola seems to treat us worse than a step child........
acarleton2000
Minnesota
Hey, so the red light flashing issue reminds me of something I ran into over the years. Were these radios recased before you bought them? If you turn the radio on and get the flashing red light, can you key it up and clear the flashing light?
Not sure on the zone button issue. Might have something to do with the cap max and I have never been exposed to that type of system flashed into a radio.
pdtek
Thank you for the reply, The local Motorola shop tech answered my question. Turn scan off. The configuration writer had it turned on from power up.
I agree about the cap max possibility. Still looking into that.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
It is scan. I cap max, you can have permanent not editable scan members that the end users cannot shut off. We use those type of talkgroups to simulate all calls on systems where there are multiple user groups requiring different all calls. TT
acarleton2000
Minnesota
It's also caused by mismatched firmware between control head and radio. Rewriting the firmware or recovering the radio in CPS will resolve it.
Nailed it right on the head, This is what I was getting at with my questions. If the case had been replaced recently it can cause the red light flash.
acarleton2000
Minnesota
Correct me if I'm wrong but isn't scan an orange light flashing, not a red light. I was wondering if that was a mistake in the OPs original post as well.
TampaTyron
Phoenix, AZ
The orange and red are so similar that I consider them the same from the perspective of the end user. TT
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
I was about to comment the same. Red and orange are different indicators for different things. Yellow=scan, red=error.
