Disabling transmit
levigne25
edmonton alberta
Hello I just purchased two baofeng uv-5re , can anyone tell me if I can disable transmitting on certain frequencies ? I enjoy listening to the public service frequencies but afraid to accidentally TX on them ?
ermin
Jacksonville Florida
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_1_4 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10B350 Safari/8536.25)
I believe you can only disabe transmit for the whole radio. (UHF side and / or VHF side). The two that I have only do that. Not by channel. If you do not put a split in it it will xmit on the freq you are listening to.
73
Ermin
In the Western US Mountains :)
if you have programming software what I do is just program 500.000 mhz on the transmit side that way the radio will either beep back at you or just say no TX on the display or something like that ....but I don't have a bofang so UNSURE if that will work......
nd5y
Wichita Falls, TX
If you are using CHIRP programming software the proper way to disable transmit is by setting the Duplex column to off. Setting a radio to transmit ousidet of its designed frequency range could cause problems.
