I just picked up my 436 and am quite disappointed in the charging method of this unit. The inability to charge the radio while listening is a huge downfall.
I get the idea of using a mini USB to charge and connect the radio to a computer. Uniden could have at least included a small USB wall wart so it could be charged from a 110 outlet. I had to use the one from my phone. What was wrong with the 396 set up of a power input and the mini USB used for
But, I listen to my radio at work most all day and then at home or out in the evening. With my 396XT I could listen all day while charging at my desk at work, then take the radio home and run it on batteries until I shut it down to go to bed. I never had an issue of dead batteries when I wanted to listen. Now it looks like I will have to have a second set of batteries on a seperate charger to accomodate Unidens shortfall.
As for the SD card "holder", what a crap design. It is ok if you are going to put a card in once and leave it, but if you are going to be using multiple cards which I do for my 536, it is going to be a problem. The little metal door is flimsy and poorly designed. It has come off on me twice already in my attempt to change out the card (once). Why could they not have put a "socket" like the 536 inside the battery compartment that would have made inserting and removing a card a breeze.
Other that that, I am very pleased with the operation of the radio - so far.
Thanks for letting me rant my .02.
