KF7ZXT
I've finally finished installation of a GPS-enabled Uniden 996XT. I used an external trunk lid mount to mount the antenna on my hood. The antenna is a Larsen MNO 150/450/800 MHz antenna: Larsen NMO150/450/800 Tri Band VHF, UHF, 800 MHz Motorola Style Antenna | TESSCO
I was hoping a grounded, tri-band antenna (this antenna was recommended to me on this forum) would result in significantly better reception that the stock, table top antenna that came with the unit that I used (indoors) while programming). Unfortunately, reception seems somewhat worse - specifically, communications are getting clipped mid-transmission, despite being very strong signals on a trunked system.
I wonder if I placed the antenna too close to the window pillar. Rather than describing placement, attached is a photo
So, my questions are:
1. Is this poor antenna placement, causing interference by the vehicle body?
2. Is there a test I can use to determine interference? (I don't have such instruments, but have friends who might)
3. Is this just a poor quality antenna? If so, could I screw a better antenna into the mount I've already fixed.
I opted not to go for a roof mount simply because I spend a fair amount of time in low-ceilinged garages and dont want to put an antenna through that kind of abuse.
Many thanks.
Many thanks.
