Discone antenna and yagi antenna
Colton25
Is it possible to use a discone and yagi antenna on the same scanner?
gewecke
Banned
Illinois
It's not advisable to do this at the same time, but a vhf yagi would definitely let you hear that distant fire dept! ;)
73,
n9zas
n5ims
Possible? Yes. Will it help? Perhaps yes, perhaps no. Will it make things worse? Perhaps yes, perhaps no.
You need to be very careful on how you connect them. If you use a switch where only one antenna is connected at a time you'll avoid the issues where a signal arrives on both antennas and the out-of-phase signals mix together and cause distortion or possibly even reducing the signal level to near nothing.
For a full discussion on what you want to do, read this sticky thread on the topic of using multiple antennas with a scanner. http://forums.radioreference.com/passive-devices/113057-running-one-scanner-multiple-antennas.html
Colton25
73,
n9zas
Yeah I've been doing tons of research!! Looks like the yagi would work great however i don't want to lose my Discone :/
gewecke
Banned
Illinois
I agree, since there are times when you may not want the directional ability. You could mount the yagi right below your discone.
As suggested above , if care and the proper hardware is used, you could have your discone on a rf switch with a yagi.
Both at the same time will not work well.
73,
n9zas
Colton25
As suggested in your other thread, if care and the proper hardware is used, you could have your discone on a rf switch with a yagi.
73,
n9zas
What if i use a duplexer rather then a switch??
gewecke
Banned
Illinois
As n5ims said above, the out of phase signals through a duplexer from both antennas would probably create a attenuated signal, meaning you would not hear as much as being able to pick between either antenna.
73,
n9zas
Colton25
Colton25
gewecke
Banned
Illinois
Okay awesome, and i can put the switch at the scanner end correct?
Is this the yagi you think will work best?..... Y1503 - Antenex Professional Grade Gold Anodized 150-174Mhz 3 Element 7.1dBd Yagi Antenna
Yes...unless you want to climb up there to switch antennas? :lol:
The Y1503 should work for you great unless you want more gain then there are larger yagis with more elements, and as the description mentions the antenna will have three elements and will be much taller than the one pictured since it is vhf.
73,
n9zas
Colton25
73,
n9zas
Okay i'm not to worried about the size, it will go under the discone. Out of curiosity would you happen to know how much bigger it will be haha
gewecke
Banned
Illinois
majoco
Stirrer
New Zealand
IMHO I wouldn't fork out for a 1.5kW switch for just receiving! Much cheaper switches are around.
kf5qgf
Olive Branch, MS
So let's just plant the seed and see where it goes. What about phasing harnesses? I know in theory you can use odd fourths of coax length to help match impedence. Anyways what I'm saying is if you have a yagi, 50 ohm impedence, and a properly built discone, 50 ohm impedence, there is undoubtedly a way to match the impedences back down to 50 ohms so that it will actually be beneficial to use both. Anyways, like I said, just planting the seed, ya'll run with it.
KF5QGF
gewecke
Banned
Illinois
True, but some of the cheaper rf switches lack sufficient isolation between the ports. Diamond switches are known for having decent port to port isolation.
Also if he ever decides he wants to transmit, then he'd be set. ;)
73,
n9zas
LtDoc
Oklahoma
Craig,
If done correctly you would have the impedance taken care of. But, that doesn't have anything to do with how the signals from both antennas will combine. In phase, out of phase, both are possible and can either increase signals or decrease the desired signals. At the same time all those undesired signals will also be subject to the same increase/decrease. With just a simple feed line connection there's no way to distinguish between desired/undesired signals. It can certainly be done, but it's not a simple thing anymore.
High capability antenna switches are certainly nice to have. In my particular case they would be much more than I'd ever need (transmitting or receiving). So, depending on how 'frugal' I happen to be at the moment ('frugal' = cheap, which is dependent on my finances at any particular time), I could 'make do' with much less. YMMV, naturally.
- 'Doc
