carsonbm
I have made up my mind to buy an omi direction antnena, but I do not know what the best model is, can someone help me? :?:
Brent :evil:
Brent :evil:
carsonbm said:What antenna can be installed without taking up half of the back yard. I need all the help I can get. :evil:
N_Jay said:carsonbm said:What antenna can be installed without taking up half of the back yard. I need all the help I can get. :evil:
The ARRL has about the best books on the topic.
Spleen said:I guess I'll pile this on to the first question: is there an omnidirectional out there that lets you sacrifice range for better reception, say, like, you don't really wanna use it much above 400MHz?
Spleen said:You may have seen me discussing this in another forum, but basically I just don't want to replace my dying discone with another one, because my cable run (unchangeable) is too long to hear much above 400 MHz, so a 25-1200 discone would seem to be a waste of $$$. Below that, it works great...the discone even pulls in HF rather well, but I can probably seperate that out to a different antenna if I get motivated and replace the current discone with something designed for sub-400MHz but still omnidirectional. Lower range limit is quite negotiable. I just didn't know if such an animal existed or if I'd have to take your suggestion and make it a two-wire or shared setup...
