Discone Antenna
iMONITOR
Silent Key
S.E. Michigan
Nope - I used to have one of the ICOM discones before it was "removed from my ownership involuntarily". Used it inside quite a bit but never got the chance to mount it outside before it was no longer in my possession.
Scanner Master has it listed here: DA3200 Wideband Discone Base Antenna | Scanner Master.
-Mike
It doesn't indicate that is an ICOM. ICOM makes a few discones but that part number DA3200 is an AOR from everything I've seen.
mule1075
Washington Pennsylvania
Mike_G_D
Vista, CA
My mistake! I could have sworn the Scanner Master one I linked to said "ICOM" - I couldn't remember the model number but know the one I had was an ICOM. I used Google search and entered "ICOM Discone" and the link I gave was at the top. Like I said - could have sworn it really said "ICOM" when I clicked on the link.
Oh well, the ICOM, Diamond, and I'm guessing, the AOR model are all very similar.
-Mike
MDScanFan
USA
If price matters then consider the tram 1410. It’s ~1/8 to 1/2 the price of the other recommendations. I had mine outside for 5 years without any issues. I would not recommend it for an inaccessible installation, like the top of a tower, but for mounting to a house or attic it would be fine.
iMONITOR
Silent Key
S.E. Michigan
-Mike
No problem. To add to the confusion there are several other manufactures making something very similar.
jonwienke
More Info Coming Soon!
VA
I have one indoors. It works great, but I would get a better quality unit for an outdoor tower mount.
majoco
Stirrer
New Zealand
I don't know who made mine but it seems to have fatter elements than most - it was 'liberated' from the roof of an aircraft hangar that was being demolished (with permission of course!) way back in the mid 90's and has never let me down. Not shown in this pic is the little shroud for the N connector made out of a plastic pill bottle - it's bone dry in there but the spiders love it! I think this antenna is more likely to be a professional product rather than one you could buy cheaply from your ham radio outlet - all the elements are filled with foam which I imagine dampens the mechanical resonances and the central hub is a couple of aluminium castings - the elements are bolted on into a hemispherical slot.
prcguy
Yup, that looks like a nice commercial quality Discone you have there.
iMONITOR
Silent Key
S.E. Michigan
I don't know who made mine but it seems to have fatter elements than most - it was 'liberated' from the roof of an aircraft hangar that was being demolished (with permission of course!) way back in the mid 90's and has never let me down. Not shown in this pic is the little shroud for the N connector made out of a plastic pill bottle - it's bone dry in there but the spiders love it! I think this antenna is more likely to be a professional product rather than one you could buy cheaply from your ham radio outlet - all the elements are filled with foam which I imagine dampens the mechanical resonances and the central hub is a couple of aluminum castings - the elements are bolted on into a hemispherical slot.
At first glance I thought it was possibly a Kreco, but there are subtle differences.
majoco
Stirrer
New Zealand
Don't forget I'm in New Zealand and we did have some good antenna manufacturers here - Deltec made some good stuff and Lincrad makes good solid TV antennas like this one.....
TailGator911
Silent Key/KF4ANC
Fairborn, OH
I am sold on the Diamonds, have used them for years. The big one on my house and the little one (220n) on my Winnebago Via. I don't leave home without it ;)
Rt169Radio
CT
I have a Diamond discone for one of my scanner antennas up on my house for years and never had a problem with it recoption wise or build quality wise.
So as you can guess I recommend a Diamond discone :D
