Discovery sessions
Pcamp1227
After completing a Trunked discovery session will the scanner automatically start scanning these results? Is there anything else that has to be done for the scanner to start scanning the discovery sessions?
jonwienke
More Info Coming Soon!
VA
Many of the frequencies will be part of trunked systems, and you'll need to program them as such before you can scan them properly. So it's not an automatic thing.
Pcamp1227
I see. The discovery log just shows a list of new TGID's that were found , the seconds spent on each TGID etc. I'm wondering how to program these into Sentinel?
u2brent
OAMPT
KRWDPAXKRS1
I believe user intervention is required, If you're referring to TG's discovered during the session. They would need to be added to the System in it's FL/Dept manually before you'd see them while scanning normally.. :unsure:
