Question for the group.... I was playing around with a few of my tapped radios to see if I could get better decoding from them. I typically monitor a local EDACS system and while using a tapped Pro-43 as the source my decode rate would typically be in the high 90's, if not 100%. I swung my setup over to a Pro-2045 that I tapped years ago and had been using for monitoring a VHF Motorola system with Trunk88. When I use the 2045 on the EDACS system, the decoding is abysmal.. down in the 60/70% range (using EWTrunk). Using UniScope I can get a decent 'eye pattern' on the Motorola system, but nothing but fuzz on the EDACS system (with the sample rates set to 3600 & 9600 respectively). I tried different combinations of caps and resistors on the tap with no change (the Pro-43 is just using a 10k inline on the tap, no capacitor).
I guess basically I'm asking... have others here found that some scanners just plain have crappy discriminator audio and are poor choices for driving decoding software?
