Discriminator tap
dynamitedjs
Richmond, Va. (Mechanicsville)
ok, I found IC 201, and the MC336 Chip.
PRO-39 MC-3361N IC-201 9
where is the 9 pin or baseband audio pin or whatever that I connect to?
heres the pic of it:
Pin 1 is directly under the dot - in the lower left corner of the chip.
Counting from left to right you'll find pin 8 on the bottom right corner of the chip.
The pin you want ... pin 9 ... is directly above - on the top right corner.
Since you'll also need a ground connection ... pin 15 is ground (just right of pin 16 in the top left corner directly above pin 1).
For more than you ever wanted to know about that chip (like pin-outs) ...
http://www.qsl.net/n9zia/spec/mc3361.pdf
-rick
