baddandy23
Dumb question, but is the discriminator tap on the Pro95 or 96 the same as the PC/IF jack? Or is the tap a mod that has to be installed seperatly? And if so, how is it done in a nutshell?
baddandy23 said:so is it then not possible to use mtrunk or etrunk without the tap?? thanks[/quote
Yes, but that's not the only thing you would need; you also need something commonly referred to as a data slicer. There are still 1 or 2 companies that sell them; briefly put, they take the signal from your tap and change it to a RS232 signal that a PC can read.
In addition, if you're the tinkering type, this site has schematics for data slicers. These are external devices, though if there's enough room I know of a few folks that have put them inside their scanners.
73s Mike]
ka3jjz,ka3jjz said:Yes, but that's not the only thing you would need; you also need something commonly referred to as a data slicer. There are still 1 or 2 companies that sell them; briefly put, they take the signal from your tap and change it to a RS232 signal that a PC can read.
baddandy23 said:well i guess what i am getting at is I was wondering if I can run Mtrunker without putting a tap into my pro 95 or pro 96? do i just need the data slicer, or do i need the data slicer and a tap. and where would i get a slicer at?
crayon said:Windows trunker port "Motorola Trunker32" do not need a data slicer to operate correctly.
