Discriminator taps
Mattsenft
Harrisburg, PA
Does anyone know where I might be able to find discriminator tap information on newer GRE scanners (such as the pro-2055). I couldn't seem to find anything using the reference links in the Wiki. All the sites had mostly older equipment.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Specifically for the 2055; since this is the brother to the PRO-97, it's likely the board is very similar if not almost identical; so the links found here should work...
http://www.radioreference.com/wiki/index.php/Pro-97
And there are more than a few groups looking into things like discriminator taps; you can find them at...
http://www.radioreference.com/wiki/index.php/Discriminator_output
I wouldn't ignore the various Yahoo groups devoted to the individual scanner, either - they are often the source of some of this information in any case.
73s Mike
