R8600 Display Went Totally Black Today
wv2vvl
Bucks County, PA
I caught my display going black when I first got the receiver. I haven't found the part about the screen saver in the manual. Like everything else in the 8600, it is all programmable. You could probably deactivate it.
I just grounded both the 8600 (to a water pipe) & my mast, which is 3 5' Rohn mast sections from eBay, I used a prof. grade pipe clamp to attach to the mast. Drove in a nice 4' copper ground rod. Our soil is acid, so that means good conductivity. After grounding I felt not only safer but also note maybe a slight improvement: 45-46 dbu increased to 48-49. It may just be conditions. But I'm listening to a NY Center transmitter in Yardley, PA, & that is about 10 miles distant but my antenna is only 15' AGL. So I'm very satisfied with mine.
kg4zqz
tks for this discussion, folks... just got an 8600 today... due to qth restrictions and living in the lightning capitol of the US, my 8600 is on battery power and an active loop antenna... will check on the screensaver settings.. upgrade to 1.35 was fast and easy
