Not "Districts"
rs96 said:
Does anyone know what the district numbers are for the Sheriffs district numbers in the State of Ohio???
If you get a State of Ohio map and start with the 1st county in the "A's" and go through the alphabetical list, you will get EACH county's assigned number. The sheriff's offices don't have "districts" like the Highway Patrol does....
As an example, Franklin County is "County 25" while Gallia County is "County 27"....Meigs is County 53. Vinton is County 82.
Get the map. Count (actually, they may be numbered on the map already) and check them out....
Steve/Gallia
