Afternoon,
bringing an old thread back from the dead ( DIY Apollo Pager Programming Cradle? )
I tried to make a programming cradle out of a charger based on the information found here, not sure where I went wrong, or if i am missing something, but the VP200Pro V2.3.4 is not able to read the pager. I used a standard charger, soldered wires to the pins pictured in that thread, and ran them out to a serial connector. Is there some sort of special connector I should be using instead? I have tried it on 2 computers, one with a serial port, one with a usb/serial adapter, no luck at all.
yes the pager is in programming mode.
Any ideas appreciated.
