DIY Receive Multicoupler
kb2tuc
New Jersey
I've used the search function but am not able to find the info I am looking for. I have 6 SDR's that i would like to feed with one antenna. I do not have the budget for a striedsberg and am looking for details on rolling my own. In all the posts that Ive waded through, I can not get a solid grasp on details surrounding amplification, filtering and overall what is needed to be successful. The 6 receive only SDR's are monitoring frequencies in 120-160Mhz and 405-470Mhz. I have a dual band gain antenna mounted on tower with RG6 feedline into the shack. I am planning on feeding the antenna to a commscope cable drop amplifier # CSMAPDU9VPI then split it out to the 6 sdr's with a F Male - SMA male barrel connector. I then saw something one of the posts that this type of drop amplifier will not work but was unable to extrapolate why (in order to select a more appropriate product). Can anyone share some feedback on what products youve used to accomplish this task and how its working for you? Is a preamp needed prior to the drop amp? Can a receive preamp be used with just a simple multi way splitter? Thank you for taking the time.
prcguy
This thread has info and post #46 shows a 4-port multicoupler I made but its since been upgraded with an 8-way divider and the amp was swapped for a 20dB gain ZHL-2010. Attenuation after the amplifier was changed to give about 2dB gain per port at the output.
alabamarailfan
I have seen the Electroline splitter/signal booster mentioned by several people on this forum. So I decided to try one out. I now have three of them in use (two 4 port, one 8 port) and have found that they are satisfactory for receiving both with SDRs and "hardware" radios. I am sure there are better options out there, but for the money, they have worked great for me. I monitor the same basic bands that you are.
Here is one of the models that I have used: Electroline DropAmp EDA 2800 8-Port Cable TV HDTV Amplifier Signal Booster | eBay
Beaverton, OR
I acquired a ChannelMaster eight output amplified splitter. Some time ago I purchased one of their TV antenna amplified splitters and have had good luck with it. It's available off of Amazon: https://a.co/d/aOjBMGs
Prior to actually using it, I bench tested it with a NanoVNA and found that the unit was well within spec'. I use it for VHF, UHF and 800 MHz reception. It provides a slight signal amplification with only a few dB increase in the noise floor. ChannelMaster makes pretty robust and solid products.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
My setup is a little extensive
I have 3 band specific antennas - PCTel 800 Mhz mobile antenna on a ground plane, 450 Mhz mobile antenna on a ground plane (forgot the brand, might be PCTel also), and a KB9VBR slimjim for VHF. The slimjim is basically 2 j-poles on top of each other. Contrary to what some may claim, does quite well.
All 3 antennas fed to a Diamond mx-3000 triplexer, minicircuit's FM band filter, and then fed to as GPIO Labs low noise amplifier. Length of coax goes to the next room where I have a minicircuit's power splitter. I'm not at home right now, so I can't recall exact model of the splitter.
The LNA is important and necessary to recover the losses from the splitter. I used to use a TV splitter, but I kept losing inputs, so I to upgraded. Recommendation for the LNA came from @Ubbe .
Hdc30474
For the price, the Electroline are hard to beat. They are the best low cost solution I have used. They are low noise with sufficient gain to compensate for feed line loss. I use a 4 port to feed 4 receivers from one antenna. The amp should be as close as possible to the antenna. They are often available on Amazon. I also use the power injector.
