GKLdiy88
- Joined
- Jan 25, 2022
- Messages
- 206
Hi all !
I am getting back into SW listening after roughly about 20 years away from it. I had used a DAK DMR-3000 with the included antenna amplifier and it had worked good even in the big city we used to live in. Anyhow after digging it out of storage the few stations it now gets are all so extremely low in volume you can barely hear them, so I figured all those years of storage was not good for it
So being on a budget but still wanting something reasonably good, after doing much research I ordered a C Crane CC Skywave (not the SSB version).
We now live in a semi-rural area on the edge of a small town, the biggest city being about 25 miles away. My main focus will be listening to SW broadcasts both from the US as well as from overseas, but will also check the airband occasionally since there is a small airport not too far away.
Anyhow, back to the reason for my post, I was doing a lot of research on making a DIY antenna wire, one where you have an alligator clip to clip it to the whip antenna.
Seems there is a wide variety of views as to what length to make the wire so it does a good enough job at improving reception but not so long as to risk overloading the portable receiver (which I read where portables are more prone to overload).
Doing a search online for such info one result was on a web site called SWLing which included this (quote) " To be on the safe side, do not attach any wire to your portable that is in excess of twenty feet in length." (end of quote)
Other results from other web sites mentioned other lengths including 35 feet and one even 100 feet. So you can understand how it can be confusing when there are so many different opinions
I did notice that there are premade antenna wires made to clip to a whip antenna that you can buy, one such one I saw online was 23 feet long, so that made me feel that even around 20 feet must do okay or why would they sell them around that length ?
Now I simply want what will help the model I ordered (the CC Skywave) perform well enough to get overseas broadcasts, if a 20 foot wire inside the house would work, great, if I need longer I just want to be sure what risk there is of overload once you go over 20 feet. Also, IF I decide on running a wire outside, is it really necessary to have some kind of ground protection ? (I'd like to keep things as simple as possible but still safe)
Thanks in advance for any replies !
