N9ZLI
Having done a bit of research (not nearly enough) I'm curious if anyone else has ever developed their own scanning software or has ever connected that serial cable up and opened a terminal program to see if they could "talk" to their scanner. Using a very simple Linux program called minicom I hooked my Pro-528 up and opened /dev/ttyUSB0 as it if were a modem. The upshot was kind of surprising in two ways. 1. Despite what I've read elsewhere, the Radio Shack 20-047 cable appears to operate at 9600 baud instead of 115,200 (unless I'm missing something). 2. I can't get the radio to react to anything I type. That isn't so surprising, I suppose, but I did find that if you turn on a Pro-528 and hold down on the E/PGM button it puts the radio into clone mode. If you then press the up arrow causing the display to read FIRST you can hit the E/PGM again and the radio sends MDL to the serial port about 7 times then enters an ERROR state. I am assuming that this is because it did not get the response it was expecting from the other side of that serial connection. Has anyone else had any experience at getting scanners to read signals from a terminal program like this and if so, would you mind sharing your experience with me?
Thanks & 73,
Joe Denison
N9ZLI
Thanks & 73,
Joe Denison
N9ZLI
