I just brought a couple of these in to evaluate and possibly purchase more for an application they seemed perfect for. I had read complaints about the voice delay which did not worry me as I'm used to that with any digital LMR equipment I've ever used. Furthermore, the talk permit tones typically do a great job of preventing users from cutting off the beginning of a message.
The one issue I am seeing that may be a deal breaker, is that the end of messages are being cut off. I've tested the radios with a half dozen users and everyone seems to have the same issue. When they release the PTT at what seems like the right time (after they are finished speaking into the radio) the transmission drops, and whatever audio the vocoder in the transmitting radio was still encoding, drops. This results in the last one or two syllables being cut off. It is not inconsequential. If a user reads a series of numbers, there is a likelihood that the last number will not be heard.
I asked MSI tech support about it and they suggested this is a training issue. I counter that this seems like an easy firmware fix to implement - have the radio hold Tx for an additional 500 ms after PTT is released. I have used Motorola DMR and P25 radios which of course have a voice delay but this has not been an issue; those radios seem to do a good job of continuing to encode and transmit any audio that was captured right up until PTT was released. I understand this is an entry level radio compared to DMR and P25 equipment, but the 900 MHz FHSS seems perfect for my particular application, from a coverage perspective.
I've got a cable on the way so I can hopefully open CPS and check to make sure FW is up to date, just to check that off the list.
Does anyone else use these radios? Or perhaps the more fully featured DTR600/700 series? I'm wondering if this is an issue anyone else has had to overcome.
