- Joined
- Oct 27, 2002
- Messages
- 2,382
- Reaction score
- 1,400
Hi,
I have tried to research this and I've found some info, but nothing I'm trying works. As the subject asks, is anyone successfully doing this to access talkgroups that you don't have programmed? I'm attempting to do so on the TGIF Network. The radio works very nicely (for a CCR) for TG's I have programmed. I know...program the talkgroups. Well, there are of course literally thousands and a core group of them I might consider using regularly. On the fly it would be nice to access one and go.
Research led me to create a local TG9 as a channel on the radio, and work from there. I press the menu button, then Talkgroup, then Manual Dial. I punch in the unprogrammed TGID either as a private call (which some research says should be done) or a group call (press # key before entering).
I'm using a Zumspot 3.5" Elite LCD. On the WPSD Dashboard I can see that I'm keying up the TG. It becomes the current listed TG. However, the radio times out and goes back to TG9. The TG I just activated remains active but I hear no audio. I ASSume this is because the radio has returned to TG9.
Either I'm completely missing the boat (likely) or the radio doesn't work in this manner despite purporting to (possible).
Thanks in advance for any suggestions.
Scott
Scott
