DMR Cap+, Con+ Question
rkm1215
Knoxville
How does the pager handle a frequency on a DMR trunk? I know it doesn't scan them, but does audio unmute or does it just ignore them?
Mr_Boh
The Land of Pleasant Living
Do you mean like if you have a frequency that would be a part of like a capacity+ system in your list and you came across it? Would be very similar to if you have a P25 trunking system voice frequency in your conventional scan list and came across it. If you have color codes, it probably won't open (like having NAC on a P25 Voice Trunking Channel), but if you had voice come across either one of the slots in the frequency and you had it programmed it would open. Connect Plus is similar to scanning an older Analog LTR system with an analog scanner in terms of picking up the "rest" data then being able to decode the voice while talking is happening.
