SDS100/SDS200: DMR code question
RandyKuff
Lorain, Ohio
If your talking about the DMR Key that you puchased...
Once you enter it into the scanner it's permanent...
A reset won't delete it...
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
Are you referring to a stored color code from a DMR frequency in a favorites list or the DMR purchase key you used to activate the mode? Both will be saved if you Reset User Settings. However frequencies / color codes stored in favorites will be wiped if you Clear user data but the activation key will remain
