DMR data listed
west-pac
How should DMR data be listed in the DB? On the Laurens county, Georgia home page some DMR data is listed under the tone colum, but others on that page are starred out (*) and that data is listed in the channel description box "(Slot 1, TGRP 300)". Does that data need to be in the tone colum for programming softwares to see that specific data?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Yes, you are correct. Since the data is known, it should be put in the appropriate place in the tone column. A submission should be made for this correction.
dave3825
Suffolk County NY
Where you see the *, pretty sure that means those values were not submitted. But on the page you linked, the * info is being displayed in the description column. Like @mciupa says, you should make a submission requesting the tg and slot info be move out of the description column and into the tone column.
