DMR in conventional bank
Kel
Southwest Florida
Can I enter a single DMR frequency in the conventional bank or do I have to set it up as a trunked system?noticed it will pick up the noise on my 800 but on the TRX-1 can't seem to hear anything,any advise would be helpful.
troymail
Silent Key
You can program a DMR frequency as a conventional object and put it in any scanlist (not bank) that you want. You need to make sure you set it as "DMR" and not Analog/P25".
You can also program it as a trunk system but in that case you also need to add at least a wildcard talkgroup object to hear anything.
Ubbe
Stockholm, Sweden
You'll need to put at least a DMR wildcard TG in the same scanlist as the DMR channel.
Problem with the DMR systems I monitor are that the DMR standard says that an ongoing voice call updates the TG info each superframe, which is at 360mS intervals to allow for "late entry" radios, and the scanner only stays something like 100mS on the DMR channel.
With the trunked DMR list you can set a dwell time to compensate for the short 100mS scantime and scan the channel several times to hopefully catch the start of the superframe.
Set up a new trunked system and add only that single channel and a TG wildcard and set dwell to 500mS.
Be aware that my TRX-2 are less sensitive than a Uniden and also needs a noise free signal to decode.
/Ubbe
goaheadover
Banned
For some reason my radio won't monitor a conventional DMR channel. Can I program this as a trunk system and scan it that way? The DMR trunk systems decode for me but the DMR conventional just gives me a digital signal over analog audio. Thanks
milcom_chaser
Did you update your EZ Scan software to the latest version? Any version before 2.14 (Sept 23rd, 2016) mentions this issue:
"Fixed issue when editing a conventional object where setting that object to DMR mode was not being set properly. "
Once you have done that, here's a picture done in the "Conventional Frequencies" Tab of a single conventional DMR frequency setup.
