DMR in Mississippi
INDY72
Indianapolis, IN
As far as Public Safety, only a couple use DMR, Tate Co SO and Senetobia PD, Pike Co used to be DMR but is now MSWIN, Adams had added DMR capabilities but never used as far as I am aware and thy are going MSWIN very soon. One town in Simpson Co is DMR.
QuietPlease
...I'm trying to listen.
Pontotoc SO and some of the smaller PDs in Pontotoc use it. They also still use their analog.
Also, I think Aberdeen, and some others nearby use it, but I'm not in that area enough to verify it. Monroe was using DMR, but switched to MSWIN.They may still have it as a backup/alternate like so many of the other agencies.
West Point was using it, but it's been a few months since I've been there.
INDY72
Indianapolis, IN
On the commercial side: ComSouth has built out an nearly, if not completely statewide MotoTRBO Connect Plus Linked system replacing its old analog LTR systems. We only have a few of the sites logged currently as hardly anyone monitored and submitted data on the network. There are a good many school systems that have moved to DMR, and many businesses also.. Oh forgot on the Public Safety side : Meridian and Lauderdale Co use as does Kemper SO... the ComSouth system.
scanphreak
Uniden BCD325P2 with ProScan capture today close to Biloxi with rubber duck antenna RSSI 500:
451.2125 CON Color Code 1 Net0175 s0013
12/27/17 12:22:34,DMR,81060A00000000000002,CON,NET-00AF SIT-000D,UN
12/27/17 12:22:34,DMR,81060A00000000000002,UN
12/27/17 12:22:34,DMR,0A0AF0D0,CON,NET-00AF SIT-000D
While searching I found these:
461.5500 Capacity
462.2750 Capacity CC5
