In my experience with DMR, if someone sounds like garbage, they’re using a hot spot. OTOH, it can be a problem with the internet linking repeaters. But it’s rarely a problem with a radio connecting to a repeater.
Wow. That's a lot of assumptions there.
You may want to re-word your reply.
For one, the Openspot devices are generally very decent. Yes, there are garbage ones out there for sure. But it is unfair to say they all suck.
Second, there are so many DMR repeaters kludged together with worn out analog radios with a MMDVM type of board hanging between it's not funny. If an old radio doesn't meet spec on analog, it isn't going to meet any spec on digital. So, there's a huge variable right at the repeater itself.
Third, hams are cheap. There's a good bet that tower site doesn't have a landline based ISP available (DSL,Cable or fiber). Even if it did, it's probably too expensive anyway. So, there's probably some low end cellular device or cheap point to point link going.
Fourth, that $20 unmanaged switch will probably auto negotiate you to half duplex and you;d never know it....ever. Causing all sorts of problems when streaming audio/video..etc. Web surfing would probably never show any issues. Using a managed switch is a must for streaming services so you can be darn sure you are connected at the speed you need to be and full duplex.
Fifth, That $30 router is probably barely able to handle streaming services. I found the gamer grade consumer routers to be a bare minimum for home use. Yea, they are $120 but you won't be replacing it when wi-fi dies in two years and will handle any streaming you throw at it. If someone has the skills to handle commercial/enterprise networking gear, even better.
Sixth, some ISP's are better than others. If the ISP sucks, then you're screwed until another one is chosen.
So, my point is the entire pipe from one radio to the other has to be spot on. If there's a shady piece of equipment in the way, then the rest of the pipe will suffer. The fun part is finding what piece is the culprit. There's advanced networking products out there that will tell you exactly whats wrong, but is out of the comfort zone for *most* hams. If the shady device belongs to an ISP 3 states away, then you are rather stuck until the net re routes your link another direction. When using the internet to link things, you are at the mercy of the net with no control outside of your home.
