DMR Pager?
RadioRammler2
Europe
Hi
DMR support sending Text Messages over the Air to Radios. Does any Company build an cheap DMR Pager out of that Technology who can (at least on the Paper) only receive thinks and where the user cant send anything back?
Thanks!
Project25_MASTR
TX-COMU
Texas
The problem with DMR paging is that it's actually a two way exchange as it's built around the Call Alert function unless a manufacturer has figured out a way around that (maybe Simoco, Tait or Hytera). That's an existing problem with protocols like P25 and NXDN as well though P25 has been updated for two-tone over the CAI so you can send blind pages out.
RadioRammler2
Europe
Like my Hytera Device does send out SMS without confirmation. I know like every Pager without a "return Channel" you never know if it got received. I would say the good thing is since DMR use 2 Slots the 2nd could be use as an return channel if the Device is physically in range.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
You could send group text messages (i.e. messages to a talkgroup). I know there was some 2 Tone Paging over DMR that a friend setup on a Capacity Max system I worked on (I recall they used SL7550e as pagers).
TT
