DMR Programming Help
RadioGuy3007
Hello,
I have an XPR6550 and I am trying to program a channel to listen to. I was told I need a color code. Is there a default one?
RayAir
Hello,
Color code 1 is the most common.
However you still need to know the time slot and the talk group number.
I've seen systems set up as simple as:
Ex- 463.625 CC: 1 TS: 1 TG: 1
However it could be CC:14 TS:2 TG: 1356005
So you really need to run DSD+ on the frequency you want to monitor. Sure you can guess color codes and the time slot, but the TG could be near impossible to guess.
DSD+ will tell you all of the above so you know how to program your XPR 6550.
XPR 6550 is a good radio. I mostly use mine to monitor Capacity Plus systems.
Good luck.
