DMR RC 4
werinshades
Chicago , IL
[QUOTE Like Crack for a Scanner Addict![/QUOTE]
This is too funny!!
Downloaded, applied to a 536 & 436, updated Sentinel and all is good in the Uniden candy land!
(1. Modified delay time working in CAP Plus)
I can report it is back to working properly. Thanks Paul and the team again!
racingfan360
Thanks, Its there so something else is going on.
I think the easiest way to verify is to pick the frequency of a busy and strong signal DMR system near you, and punch in this frequency as a Quick Search Conventional channel. If you hold on this channel it should show DMR decoding when the system is active.
buddrousa
UPMan item #3 I have 4 Conventional DMR Repeaters I am seeing everything but the USER ID's on these systems. If I set them to 1 Ch DMR Trunking I see all the information.
UPMan
In Memoriam
Arlington, TX
For about an hour the link included Sentinel xxxxx.02 instead of xxxx.03. The d/l file has been corrected.
bravo14
Polk County FL
Awesome work guys! I updated to new firmware and see unit id in CONV mode. I'll try see if any loss in p25 or analog stuff around me. I think the 436hp is deaf on some uhf dmr stuff.
n2pqq
It would be nice
to see a finished product !
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
It would be nice
You clowns complain that things are "released before their time" or that "we are beta testing this junk" and then you the same 'junk' to be "a finished product" rather than continue testing to stamp out any remaining bugs. Just proves there's no pleasing the lunatics in this asylum.
werinshades
Chicago , IL
Yessss!!!!! Nailed it! They haven't figured it out yet, we are the "extended" beta testers!
WX4JCW
Stow, Ohio
People are so picky these days,
Your comment wins
Sent from my SM-N910V using Tapatalk
bravo14
Polk County FL
..+1
buddrousa
The only new thing I see is TS at the very bottom right on the screen and CC by the frequency. This is a conventional system I have had programmed from the 1st DMR release.
racingfan360
buddrousa....if you have populated the Alpha Tag field, then it won't show either TG or Unit ID. If you don't populate it, and/or let the scanner populate it for you and defaulting to filling it in with the frequency in MHz, it will show the TG and Unit ID. This is why I asked for this feature to be resolved in post #20 of this thread.
trido
Retired 32 years scanner sales
Southern In
3. Added unit ID display in Conventional DMR
I tried this on 3 dif scanners not seeing unit id's in conventional mode.
now on a trbo con + system yes i have unit id's
Is anyone?
jeff
cellphone
Silent key.
Ahwatukee, AZ (Phoenix)
Works for me. If you have a name associated with the channel, it will not show. Hold on a conventional channel. Press "E YES". Select edit channel, edit name, press ". no" twice to clear the name and "E YES" to save changes. Also make sure audio type is set to All or Digital Only.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Is anyone?
jeff
I see it when searching.
Searching is now awesome as you see the TS, TG, CC and UID. And if it's Con+ you get the Network and Site ID.
trido
Southern In
thanks that worked
buddrousa
That was it thanks
