D
DaveNF2G
Guest
Right click in the empty gray area next to the check boxes; a menu pops up that allows you to set all on or all off.
Wow! I had no idea that feature was there. Thanks!
Posted, now. No change to Sentinel (if you are fast, you'll get a file w/o Sentinel in it, but I just realized that I need to add Sentinel to that file for those who might just be joining).
Like Crack for a Scanner Addict
I'd LOVE to buy a key, but Uniden tells me I can't because I'm in Canada, eh? Apparently they aren't able to process Canadian credit cards.
It's almost sounding like all bugs that have been found are fixed!
With any luck Friday will be full release Friday!!!!!
Took mine several timesThey took mine just fine.
Hopefully Uniden will come out with an NXDN upgrade in six months or so, then we can do beta testing all over again. This has been fun!
Well my 436 just died off to the repair
Sent from my SM-N910V using Tapatalk
I've got problems using a capital one card for both upgrades. Try using a different card... For PV I used a European Visa, for the DMR I used an ATB Mastercard.I'd LOVE to buy a key, but Uniden tells me I can't because I'm in Canada, eh? Apparently they aren't able to process Canadian credit cards.
I would like to see the time slot added to DMR conventional (maybe put it as a subsection to the color code menu). The system I am trying to monitor, its not practical to use DMR 1 frequency.
I am monitoring a Moto turbo IP site connect system. The system is a multi campus single or double repeater at each campus with each channel defined by frequency and timeslot and not by TG.
The problem is all channels except one wide area are programmed with the same TG regardless of use (see example). Using DMR one frequency, the only way to differentiate campus/channels is not practical. A separate system would need to be generated for each campus repeater. I feel it would be much more practical to be able to program each frequency twice as conventional, one as timeslot 1 and one as timeslot 2. This would solve the problem
campus 1
-repeater 1 460.000
---timeslot 1- "campus 1 admin" (tg102)
---timeslot 2-wide area emergency (tg103)
campus 2
-repeater 1 460.100
---timeslot 1-"campus 2 admin" (tg102)
campus 3
-repeater 1 460.200
---timeslot 1-"campus 3 admin" (tg 102)
---timeslot 2-wide area emergency (tg 103)
-repeater 2 460.300
---timeslot 1- "campus 3 admin 2" (tg102)
---timeslot 2-"campus 3 maintenance (tg102)
