DMR Release and Last Chance for $50
garys
Texas
I have used it, but not for DMR yet. I don't know much of how error correction works, but the audio seems to be improving the longer it runs.
Also, I might have to buy a GPS and start using location control for the DMR systems. '
I'm still playing around with the configuration of the DMR systems. I might make them FLs instead of two systems within an existing FL and see if that helps with the scanning the various sites.
Lots of new stuff to try.
I don't know if you utilize the Volume Offset feature, but this does help. I also notice this is sometimes "user" error as some don't know how to speak into the radios, microphones etc.
So Far Away....
Whilst some are snickering at 50 clams to do each upgrade...
Im looking froward & wondering how long til I can give UNIDEN
my payment for the NXDN prerelease...
Again..First Class Service from UNIDEN!
Just wish there was an option for the 436 to utilize the Andriod
App...
And also...
MDC1200!
Still chasing that dream!
K2KOH
Putnam County, NY
Again..First Class Service!...
App...
And also...
MDC1200!
You may not see MDC, but I have a feeling the NXDN will not be a charge.
K4EET
Chaplain
Severn, Maryland, USA
To Uniden in general, thank-you for your fine products! To Upman, thanks for trusting us enough to be quasi-beta testers. While I'm sure some of our comments were already documented by the "official" beta testers, hopefully we caught a few extra anomalies and documented them well enough to be reproduced by your team. You too deserve some time off because we know that you were working during your vacation a while back. Finally, to your software engineer that is taking a few days of well deserved time off, thank-you as well for creating firmware for the BCDx36HP scanners making them Number 1 in performance and quality! Enjoy your time off!
73, Dave K4EET
werinshades
Chicago , IL
Back on Topic (Again)
I see we can't seem to stay on topic...so here's a contribution:
(From the Release Notes) 2. Enabled the delay time of ID channel that received as partial or i0
I was able to confirm this feature is working properly on Version 1.11.15 on a CAP+ Trunking System. I was able to monitor an I-Call and the delay on the channel held as I have it programmed. As per Version 1.11.14, on the same CAP+ system, the Delay is still functioning correctly as per release notes. No degradation of any other Digital systems noted.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Off-topic posts deleted.
Let's keep in mind that this is a thread to discuss the latest DMR release.
It is not a Uniden vs Whistler thread.
Thanks.
greggk
York,PA
Note carefully whether you are being asked for the "serial number (SN)", or the "electronic serial number (ESN)"... they are different.
To register your scanner --> SN (12 digits) can be found on the barcode label on the back of your scanner.
To purchase an upgrade key after registration --> ESN (14 digits) and Checksum (SUM) can be found from your scanner's Menu Button --> Settings --> See Scanner Info --> Firmware Version.
If the serial number on the bar code label is worn off, or if the label is not available, substitute the "260" in your ESN with the letter Z. (for example, if your "ESN" is 37626087654321, your "SN" would be 376Z87654321 ).
Thanks Guys. I was entering the number that comes up when you look at the scanner info on the screen. Wrong number. Used serial number on back and it worked like a charm. OE.:confused:
matthewn1983
Is there a possibility we can get an update to display the tg/rid etc of a P25 conventional encrypted user ? With the option to have it on to monitor/disp or skip as it does now?
Sent from my SM-G930F using Tapatalk
newatthis
Toronto Ontario
Again I echo thanks for all the hard work and results. A huge benefit would be if the conventional discovery process would log if it were Con, CAP or DMR modes. It shows in search mode so system must be able to capture the info.
Is there a change to discovery options that does this which I am missing? I would love to be corrected and updated Great work all
