DMR Release and Last Chance for $50
KC4ASF
Fredericksburg, VA
The scanner is smart enough to know where to put the decimal in the frequency. Just key in the freq and press enter. Good luck.
Sent from my SM-G900V using Tapatalk
dallascowboys
Dothan Alabama
DMR
Got it, do I feel stupid did not see the dash when I scrolled, Thanks UPMan and your crew for working so hard on DMR and other things so us scanner enthusiast's can listen to what is going on.
Again thank you all for responding to my post.
jpb
DMR and Squelch
I initially set up some ham UHF DMR repeaters just by frequency and "NAC/Color Code" Search. It appeared that I need a fairly strong signal to hear anything. After getting the release firmware, I added several systems as "DMR One Frequency" and loaded all the talkgroups. I discovered that the scanner would stop on the "conventional" frequency and show the received color code, but there would be nothing when I switched to the DMR system I created. I got the system to start decoding when I dropped the squelch setting to zero. I'm using an external antenna, so I should have no issue receiving the repeater about 12 miles away.
This may also play into the UHF sensitivity discussion in bearcat's thread, but clearly dropping the squelch setting to zero is not a workable solution. Has anyone else noted this behavior with DMR systems?
UPMan
In Memoriam
Arlington, TX
FYI: IT Guy caught up on his work. I believe the $50 has now moved up to $60. Thanks to all the early adopters. Once the database support is added, we'll move the price up to the final price (I expect to do this on 10/1, but that is just an expectation, not a promise).
z31jaime
Thank you for your hard work! What's the next project we can help with?
Sent from my SM-G920V using Tapatalk
troymail
Silent Key
The 'work-around' for poor UHF reception on the 436 is generally targeted at the situation when using a top-mounted (by design) duck-type (portable) antenna. It isn't likely to solve problems if you are using an external antenna. However, you may want to give it a shot if you can get your hands on a piece of tape (we all seem to be buy whole rolls of it - 10 feet, etc.) - or you could wait for Uniden to agree there is a problem and wait for their solution.
frankcal
Middle Swan Western Australia
I believe the Aussie 436's suffer a similar problem as evidenced by this video which was posted on a couple of Aussie based Facebook pages -
https://www.youtube.com/watch?v=E1_zylK6vgQ&feature=youtu.be
K4EET
Chaplain
Severn, Maryland, USA
I guess I missed the sale, I went to do the DMR upgrade and it's now $60.00.
For those still sitting on the fence, now is the time to upgrade to DMR for $60 before it goes up again around the 1st of October. See UPMan's quoted post just above this. It has been fun listening to DMR activity around here.
73, Dave K4EET
So Far Away....
UPMan, I have a lot of NXDN in my area... ;)
MMMM....
+1
ColonelMike
Shepherdsville, KY
I am sure I am not the only person who came to the forum hoping to see a beta firmware for Nexedge today! :cool:
Too soon, I know! In reality, it is probably good they haven't released it yet as I have not finished finding all the DMR freqs in my area.
(and yes, I know there are no indications they are even working on it)
KevinC
Other
Super Moderator
Home
I'm closing this since it's no longer $50 and I don't want people to get their hopes up.
