I think their may need to be some clarification regarding the OPs question
According to The Motorola Patent regarding Talkaround*
“A subscriber unit automatically selects repeater access mode, if a repeater is available, or talk-around mode, if a repeater is not available (500).
The subscriber unit initiates a call by transmitting a call setup request on the outbound channel used by the repeater (510), and by monitoring the outbound channel to detect a response from the repeater (520). If a response is received within a timeout period, the subscriber unit continues the call by transmitting on the inbound channel (530, 540).
Otherwise, the subscriber unit continues the call using talk-around mode, by transmitting on the outbound channel (530, 550). In this process, the repeater monitors the outbound channel to determine when a call setup request is transmitted by the subscriber unit (610), and responds accordingly on the outbound channel (620, 630), thereby indicating its availability. The repeater then monitors the inbound channel and retransmits, or repeats, signals received via the inbound channel, on the outbound channel (640, 650, 660).”
Further, what i found on another website regarding what i think we are now talking about regarding Dual-slot TDMA simplex operation.Motorola refers to this as Dual Capacity Direct mode, and this is very different then Talkaround detailed above.
Dual Capacity Direct Mode
From Wayne Holmes (DJ0WH)
“a feature available in all second generation MOTOTRBO radios which allows two slot operation on simplex. Not only does it offer two slot operation but is also currently the only product which complies with ETSI TS102-361 §1-4 v2.1.1 for 6.25e operation on simplex.
DCDM - also known as 6.25 kHz Equivalency Direct Mode (6.25e DM) - provides additional spectral efficiency by supporting up to two simultaneous Direct Radio-to-Radio Mode subscriber calls within a 12,5kHz allocation of spectrum.”
Now, i have looked at the ETSI TS102-361-1(2) standard and i am sure if the (Rx) frequency is identical to the (Tx) Frequency.
I am not sure about everyone else but i have learned one heck of alot during this short time researching this topic.
