When referring to the HP/Agilent 8920 series of service monitors, please use the word "fabulous" in front of it, as in the fabulous HP8920A. Sorry that doesn't help the OP in his quest but I wanted to set things right.I wish.
I use an Aeroflex/Viavi 3920 myself and the software alone for the correct version of DMR (MotoTrbo in my case) is about $6000. For analog mode, you can use many older test sets, such as the HP8920 RF Communications Test Set, which can be found much cheaper than a digital test set. However, for that digital mode, if there is a cheaper option, I would like to know too.
The Aeroflex/Viavi 3920 series is coming close to end of support, and their CX300 is not what I need. Looking at the Astronics Freedom 8000 series now as a possible replacement.
By the time I got all the options I needed (or wanted) on my 3920 it was over $60,000.I wish.
Yes, with MotoTrbo, LSM, APX4000 FDMA options, and now TDMA for APX6/8k radios, several of ours here at work are nearly $100k. Long range budget planner had $5k per test set in budget, his head almost spun when I said the basic 3920 chassis was $40k each.By the time I got all the options I needed (or wanted) on my 3920 it was over $60,000.
I will second that on the HP/Agilent 8920 series test sets. I have a personal one, and at work I have all of them kept as backups to the Aeroflex 3920's, just in case (as the UHF and multiplier circuit for 800 MHz fails often now). Or the spinning hard drives that Aeroflex puts in them fail.When referring to the HP/Agilent 8920 series of service monitors, please use the word "fabulous" in front of it, as in the fabulous HP8920A. Sorry that doesn't help the OP in his quest but I wanted to set things right.
I am hoping there is some option for a service monitor that can help test/tune DMR radios that is not multiple thousands of dollars. Is there anything out there that fits this?
I just can't get used to the UI and the boxes are awfully slow when it comes to booting and switch digital protocols.
Totally agree. I've got a (personal) Fabulous 8920A, love it. Got it on eBay for several hundred bucks including the tracking generator option. After I got it I bought the color LCD display replacement and had a shop install it; made a huge difference in usability.When referring to the HP/Agilent 8920 series of service monitors, please use the word "fabulous" in front of it, as in the fabulous HP8920A. Sorry that doesn't help the OP in his quest but I wanted to set things right.
Viavi 8800s and my dry fingers don't work well together. It's been 6 years since I used one (which seemed to be about half its boot time...), maybe they did a firmware fix.
Mouse works loads better than the touch screen...I think I updated mine earlier this year. Yeah, the touch screen is frustrating. I keep meaning to attach a keyboard/mouse to it to see what it'll do.
I worked for a company that had a fleet of ships, with racks of radio equipment for emergency response efforts (hurricanes, floods, oil spills). We had to check the radio equipment on board, and one co-worker of mine had a habit of sliding the radio test sets along the edge of the gangway railing, instead of carrying them by their carry handle. Well, this meant he lost two of them overboard, about a year apart.I would like to hear the story on the 8920 that went for a swim
