DMR setup
XPS720
Windham County, Connecticut
How do I set up a DMR frequency on Sentinel. I located 6 frequency used by a local school. This is the closest DMR being used. Now I want to set up for my BCD536HP.
W8RMH
Feed Provider Since 2012
You can manually program and custom name items in Sentinel as well.
You will also need Sentinel for firmware updates as ARC doesn't have this feature.
tglendye
If I recall correctly, there are a couple of things ARC will do that Sentinel will not, but for me it doesn't justify the cost. I believe ARC will give you some remote features, but you need the computer hooked to the scanner (you may as well control the scanner from the keypad). And In ARC, you can capitalize alpha tags after you import from the database. Nice feature, but I can live without it.
mikewazowski
Staff member
Central Ontario
Please don't ask an unrelated question in someone else's thread. Thanks.
