DMR SITE ..
NP3Z
Utuado,Puerto Rico
[TD]
WPRK760 HIGH TECH COMMUNICATIONS (DMR)[/TD]
I want to configure this frequencies into my trx-1 , since it have different sites and frequencies which way if the correct one to put it in? all in a row or by sites? I already did it by sites but not working, if there another settings need to be make for DMR? is FM O NFM? Many thanks
The license says the emissions designation is
20K0F3E *Frequency modulated (FM) analog voice,
5 kHz deviation; "wideband 25 kHz" (FM mode in RadioReference.com Database)
Why do you think this is DMR? Additionally, this is an SMR type system, see below
NP3Z
Utuado,Puerto Rico
A work partner have that system configured as DMR and it works , but programmed in my trx-1 but nothing heard with and outside antenna or portable .
They may have switched modes then, just going by the license. You should use EZ Scan to load it into the scanner and it will set it up for you, since it is in RR database.
Using Preferred method of import go to Puerto Rico then the county/town one of the sites are in and select trunked systems, then choose the sites and TGs and import where you want it.
