DMR talkgroup problem
Rik
Wake Forest, NC
I have two Btech 6X2 PRO radios (same as Anytone 878). Both are experiencing this problem.
I recently added a talkgroup to use via my hotspot to connect into an area cluster of repeaters.. If I have the portable radio selected to the channel for this talkgroup, I can talk and receive on that talkgroup just fine. I have set this talkgroup up as a static talkgroup at Brandmeister.
While monitoring this talkgroup I frequently hear a transmission (and see the screen information) from someone talking on talkgroup 91. When this happens my screen indicates this is a Private call. When the person stops transmitting, my radio indicates I missed a call and adds them to the Call list.
Has anyone else experienced this? Is there a fix for this?
Rik
WA4BAN
chief21
Summer - Western NC; Winter - Tampa Bay FL
My 878 doesn't do this anymore, but I don't recall exactly which setting I changed to stop it.
Try the following settings under OPTIONAL SETTING in the CPS:
-Display/LastCaller/OFF
-Digital Function/FilterOwnIDinMissCall/ON
Rik
Wake Forest, NC
My settings are already as you indicate.
Rik
Wake Forest, NC
Each time this happens, a entry is added to the Missed Call list with the following:
q535-15-15 15:15
Rik
Wake Forest, NC
This problem appears to be solved. At the suggestion of a couple of local hams with more DMR experience than me, I deleted the static talkgroups I had set at the Brandmeister web site. It has been 12 hours since and not one occurence, evidenced by no no missed calls recorded in the Call log. So, I will be operating with dynamic talkgroups going forward.
