DMR TG99 - DMRsimplex
chief21
Summer - Western NC; Winter - Tampa Bay FL
In the documentation that I have read, DMR talk group 99 is listed as DMRsimplex. However, when I program this talk group into DMR simplex channels in my radios, I am not able to talk from radio to radio when a DMR simplex frequency is selected. Is this not the correct use of talk group 99?
John AC4JK
N5AMS
Houston,Tx.
make sure that you have both the input and the output frequency's the same and you have the color codes correct on both radios.
IAmSixNine
Dallas, TX
I also think Motorola radios dont like to decode audio if both radios posses the same user id.
Ive heard this mentioned before when guys were testing radios and it didnt work and it was recommended to not use the same Radio ID if the radios are motorola.
AI7PM
The Intermountain West
Depends on system and codeplug settings, not the brand of radio.
IAmSixNine
Dallas, TX
if its simplex then its not on a system.
and i have not experienced this my self as each of my radios has unique ID.
But i have heard several other people discuss this on amateur repeaters in Dallas.
So i guess your results may vary.
chief21
Hello,
You also have to make sure the color code and timeslot are correct.
DMR Simplex Frequencies
73 Eric
Thanks for the suggestions. Actually, the parameters in the quoted link are exactly how both UHF radios are set up...
- Four UHF simplex channels
- TX/RX frequencies of each channel are equal (simplex)
- Color code of each channel is 1
- Time slot of each channel is 1
- Talk group of each channel is 99 (DMRsimplex)
- Each radio also has a unique DMR ID programmed.
When attempting to communicate between radios on DMR simplex, there is a signal indication (both LCD meter and green LED), but no audio passes.
If I change the talk group to DMR ALL CALL (16777215), it works. When I change back to DMRsimplex (99), it doesn't.
Several analog simplex channels work fine. Any other thoughts??
John AC4JK
WNC
If you are in NC now try talking to KK4FFE on Waynesville local, they setup several radios for DMR Simplex for a recent ARES exercise
jonwienke
More Info Coming Soon!
VA
You have something programmed wrong. Post your RDT file.
chief21
**PROBLEM SOLVED**
As mentioned in my original post, I had set the programming for the four DMR simplex frequencies to talkgroup 99, but I could not get the radios to talk to each other. I've been fooling with the settings off and on for a few days, checking and double-checking each of the necessary channel parameters, all of which were shown as correct. For whatever reason (frustration, probably), I started re-setting / re-entering each of those settings in the respective drop-downs and downloaded the file to the radio once again.
Suddenly, now - it's working fine. All four DMR simplex channels are FB. My only thought is that the programming software might still be a little buggy and not totally ready for prime time.
Thanks for all of your suggestions, and keep a close eye on that Tytera programming software!
John AC4JK
fdnyfish
Barnesville, PA
Will this only work between 2 radios? or can I have 10 of my buddies all hear the same simplex conversation?
Do I need to set up Digital RX Group Call to have ore than 2 radios receive?
jonwienke
VA
Anyone within range with their radio configured properly can hear and participate in the conversation.
jaspence
Michigan
Can be either slot since it has limited range and doesn't interfere with the network or a repeater. This is not the same as talk around, which could interfere with repeater traffic.
jaspence
Michigan
Simplex
Since this does not involve the repeater, you can use any color code to make the group somewhat private. With modern scanners and radios like the CS 580, there is nothing in the ham band that cannot be monitored. CC 1 and TG 99 are the defaults most use, but there is no requirement to that combo.
