DMR Tier 1 and 2 in the database
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I'm trying to improve my understanding of how we have the DMR stuff in the database - specifically the conventional stuff. As I understand it, Tier 1 refers to unlicensed conventional, while Tier 2 refers to licensed conventional. There appears to be no direct way - short of looking it up in the FCC records - to determine which a particular listing is. So do we assume that all listings are Tier 2, or what? Mike
IAmSixNine
Dallas, TX
I believe DMR Tier 1 was more European and not seen in the USA. DMR Tier 2 in the USA is conventional while DMR Tier 3 is Trunking.
Hopefully that helps.
milf
Careful, I CAN hear you!
Indianapolis, IN
Not quite correct: DMR Trunking can be T2, or T3. Most of the UHF systems are tier 2, while the 900 MHz seems to be mainly tier 3. And then you have the Motorola stuff... All the MotoTRBO Connect Plus, and Capacity Plus systems fit in Tier 2 specs but also can have proprietary aspects by Motorola making them technically non compliant. While Capacity MAX has dual operating capabilities, it can operate in pure Tier 3 compliance, or use proprietary mode making it non compliant.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
That's interesting info, but I was asking about the DMR conventional stuff in the database - are they basically all Tier 2? Or something else?
Mike
milf
Indianapolis, IN
Tier 2. And scanners really do not differentiate on conventional. And that is the primary focus of this site.
