I just received my new Uniden BCD325P2 with the DMR upgrade. I have no experience with DMR before today, so obviously I am having trouble programming this system.
How do I figure out what LCN each channel is?
I programmed each channel into a conventional system. The first channel is the CC. It comes up DT3 on the bottom right of the display. No color code is displayed, though I did select search. the main display reads "NET0001: S0001". I can hear voice on each channel as they are used on the conventional system. If it is relevant, this system was migrated from an LTR trunked system. The radios on the system are Motorola XPR7550e.
I tried LCN 1/2/3/4/5 as they were prior to the DMR upgrade. I also tried 1/3/5/7/9. I read a couple conflicting articles about calculating the LCN, so I have tried all of the following:
CC: 1, 154, 155, 77, 78
F2: 2, 3, 28, 181, 182, 94
F3: 3, 5, 71, 224, 224, 225, 112, 113
F4: 4, 7, 779, 932, 933, 466, 467
F5: 5, 9, 401, 954, 955, 477, 478
These guesses were based on Base Freq + ((LCN+1)*0.0125) = Freq. I used both 450.0000 as the base frequency, then the CC as the base frequency, then each divided by 2. I have had no luck at all.
