danesgs
I was told that verizon or some carrier still has some analog channels in use for whatever reason. Not sure if this is for testing or company use. Anyone know about what frequency this would be?
KJ4DGE
KJ4DGE
I just did a quick scan of the band on my AR8000; don't remember the ch spacing; I have that info in a notebook somewhere. I get strong what sound like control channels around 874 - 879MHz, 880 - 888MHz, and 891.8 - 893.5 MHz. I'll have to do more research later to see if they are images or actual hits. Haven't checked that band in ages. Thanks for bringing it up. Great listening back in the 80's & 90's.
Rich
| GSM band | ƒ (MHz) | Uplink (MHz) (mobile to base) | Downlink (MHz) (base to mobile) | Channel numbers | Equivalent LTE band | Regional deployments |
| T-GSM-380[a] | 380 | 380.2 – 389.8 | 390.2 – 399.8 | dynamic | None | None |
| T-GSM-410[a] | 410 | 410.2 – 419.8 | 420.2 – 429.8 | dynamic | None | None |
| GSM-450 | 450 | 450.6 – 457.6 | 460.6 – 467.6 | 259–293 | 31 | None |
| GSM-480 | 480 | 479.0 – 486.0 | 489.0 – 496.0 | 306–340 | None | None |
| GSM-710 | 710 | 698.2 – 716.2 | 728.2 – 746.2 | dynamic | 12 | None |
| GSM-750 | 750 | 777.2 – 792.2 | 747.2 – 762.2 | 438–511 | None | None |
| T-GSM-810[a] | 810 | 806.2 – 821.2 | 851.2 – 866.2 | dynamic | 27 | None |
| GSM-850 | 850 | 824.2 – 848.8 | 869.2 – 893.8 | 128–251 | 5 | CALA,https://en.wikipedia.org/wiki/GSM_frequency_bands#cite_note-cala-2 NAR[c] |
Rich
Here is the ranges for the old GSM cell phones, Most newer T/CDMA carriers use a different band in the 1800 range I think.
there are also newer services in the 700 MHz band and above 2 GHz.
GSM1900 is missing. GSM850 and GSM1900 were the dominant bands in North America.
So far I've seen 600, 700, 800, 1900, 2100 and 2600 for LTE. 5G uses the same bands plus I've seen it deployed on 2.5GHz and 3.5GHz. Then there are the bands that are much higher like 38GHz.
KJ4DGE
