do any ge macom radios have a rang indicator
X
xts3000r
Guest
hi dos any of the ge or ma/comm have a rang indicator on there trunking side
exkalibur
York, Ontario
No radio out there has a range indicator.
Some have an RSSI meter. It only shows you the approximate strength of the system's control channel. It doesn't really tell you if you are within range of the system or not - only that you can hear the system - not that the system can hear you.
I'm not familiar with a Harris product that has such a display however.
mitaux8030
Silent Key
Home
There is in a way. If the radio displays CC SCAN then you're out of range. If it displays the system & group name, you're in range.
If you want a more accurate display of signal received, there is a function - not available on all models - that will display the RSSI in dBm.
towersites
Denver, CO
Most of the Harris-M/A-COM radios do if you program them with the FCC Menu. And yes it works in Conventional
and Trunked,
low3oh
use the menu button to scroll to "FCC menu" then one of the arrows should activate it.
Texas
The RSSI indication was first done in the 500M, and then the Jaguar 700P, 7100 and so on. MR-K, Orion and earlier radios won't display the RSSI.
