saioke
- Joined
- Apr 18, 2010
- Messages
- 90
I wanted to try my hand at installing a discriminator tap in my old Bearcat BC350A. I was hoping I'd be able to use it to scan through a few DMR frequencies. I "think" I've done it correctly, soldering to pin 10 and the other end to ground. Unfortunately I can't seem to find my Aux cable at the moment so I can't attempt to decode anything.
That being said, upon reassembly, my discriminator doesn't work at all. Rotating it left or right doesn't make a difference, so the scanner will stop at basically every frequency now. Is this supposed to happen? If so, wouldn't this method just allow you to decode one stationary frequency instead of scanning through any frequencies added to your private bank?
Edit: I turned it off and unplugged for a bit. Plugged it back in to experiment, and now the discriminator works again. Strange, I need to hunt for my Aux cable to see if it actually works.
