do i have to have...
W47331
Hello all! I'm new to the scanner world and need to know if, for a realistic pro-47, do i have to have an antenna for the scanner to work?
zz0468
Not only will you need an antenna, but you'll also need crystals for each channel you want to listen to. Chances are pretty good that the local public safety systems in your area are no longer compatible with an old scanner like that. What is it you're hoping to listen to?
W47331
yep ..
i have all the crystals for my local area but my antenna is trashed...thanks for the info
