I have a Uniden BC75XLT scanner, about as basic as you can get. I pretty much have only used it for picking up railroad communication which is my main area of interest, as well as weather radio.
The other day I thought, you know I'm sure there are a lot of other interesting things I could be listening too while driving around or at home, so I programmed in just about every local frequency on this page except for the schools, hospital, and utility frequencies. I live in Jefferson City, which is in northern Cole County.
https://www.radioreference.com/apps/db/?ctid=1504
So far I haven't picked up a single thing in 3 days of being in and out of the car and scanning at home. While in the car I'm using a mag mount Tram 1094 which is supposedly tuned to these frequencies, 30mhz-50mhz/144mhz-174mhz/430mhz-520mhz/800mhz-950mhz, and I have used it many times for 160MHz stuff as well as 900MHz stuff and it worked very well for that, so I know the antenna works.
At home I'm using a Slim Jim copper pipe antenna tuned to 160MHz-164MHz, about 5 feet above the peak of my roof, I live on the west end of Jefferson City. I know this antenna isn't ideal but I figured I should still get some of the 150MHz stuff. This setup works very well for picking up the rail band and weather radio.
So do I just not have the correct scanner for any of this stuff? Is it encoded now?
Thanks.
Thanks.
