do I REALLY need trunking?
kpl1228
Ohio
If I'm just starting out, do I really need trunking? if so, WHY?
Give me good reasons, I'm a rookie. Thanks.....
KL
tampabaynews
Keeping your PIO busy
Tampa, FL
If there are any agencies/business on a trunked system in your area that you wish to listen to, then you'll need a trunking scanner. It's up to you.
sjlamb
Sarasota County, FL
If you tell us your county, and major city nearby, we should be able to give you an answer.
The vast majority of public service comms in your area take place on Conventional (non-trunked) frequencies. Subsequently, you could monitor those agencies on most any analog non-trunking scanner. On the other hand, should agencies in your County eventually make the switch to trunked scanner (as most have been doing), a basic analog scanner will leave you in the dark.
In addition, State of Ohio agencies (including Ohio State Police) operate on a trunked 800 mHz system and that, of course, would require a DIGITAL capable trunking scanner to monitor.
The short answer is, it appears that you can get by on the cheap at this time but, that could ultimately turnaround and bite you in the rear end should most agencies in your area make the popular switch to trunked communications.
K8TEK
Ohio
Ohio doesn't have a state police. They have troopers which are traffic cops.
kpl1228
Ohio
Thanks all....I bought a used Radio Shack Pro-135 today. Nice and loud and good reception. Enjoying it. What do I miss by not having the 800mhz frequencies...are those just for trunking?
JoeyC
Senior Member
San Diego, CA
Did you not read the thread you started? You will not get the MARCS system or any OSP.
mciupa
Moderator
You will miss listening to the State Highway Patrol and Mutual Aid .
But you say you are enjoying it nevertheless, so have fun with the signal stalker and see what it will pick up.:)
