Do not use vasily fast scanner plugin
bailly2
added the plugin to sdr#, in the plugins.xml file. . turned on sdr# and it says "cannot access RTL device"
, now i have to reinstall sdr#
widowsson
Goodyear, AZ
What version of SDR# are you attempting this on?
Sent from my Pixel XL using Tapatalk
bailly2
reinstalling sdr#. ..i am in the zadig program to reinstall the driver. where do i get the rtlxxxx drive? i forget.
making a note you have to run install-rtlsdr.bat
D
DaveNF2G
Guest
You don't have to reinstall SDR#. You only have to reinstall the RTL driver using Zadig.
Vasily's older plugins are not compatible with new versions of SDR#. To "fix" SDR#, go into the file where the line that calls the plugin was added and delete that line.
mancow
N.E. Kansas
I downloaded the latest SDR# yesterday and also Vasily's plugin. Both work fine.
