HP-1: Do you have to adjust the range when GPS is on ?
rob2262
Iowa
When you have your GPS hooked up to the Home Patrol 1, and turned on, do you have to adjust the range, or does that do it for you? I have not done anything to it and I hear talking. I check the range and it does not show any orange marks showing the miles. Uncertain as I just recently got the GPS. Thanks for any help.
N9PBD
Southern Illinois (Metro St. Louis)
The range is set to 0 (zero) miles when you use the GPS with your HP-1. You can change it, but if you're mobile, it makes sense to keep it at 0, and let the scanner select and deselect systems as you move through their coverage zones.
