Do you hear things on Interoperabile frequencies?
Whiskey3JMC
Philly burbs, PA
Really depends on where you listen. If neighboring counties' radio systems differ greatly then yes, you'll hear more activity when multiple counties are involved on an incident
jonwienke
More Info Coming Soon!
PA
The analog Interop freqs aren't used much when everyone is already on the same system, e.g. MPSCS. They're more likely to be used when neighboring agencies are on different and incompatible systems. In the WV panhandle, where most everyone is on SIRN, I don't remember ever hearing any traffic on them.
StaticDischarge
Ouch! That hurt!!
Michigan
Being in the vortex of "Detoilet" I have to say yes I do hear a lot on interoperable channels. Heck, I simply hear a lot! Said it before.. This SDS200 is just like the x-wife and does not know how to STFU!! If only she came with a off knob too I might.. No, No.. coming back to my senses.. I wouldn't!..
Like Whiskey3JMC said.. It is where you are and what you want to try to listen to/for and if you do, in time, you will find some are simply not used and remove them...
jaspence
Michigan
They are used often in the area where I listen. If you are scanning the control channel, they shouldn't slow it down unless they are in use.
wtp
Port Charlotte FL
two things can happen at once...
i keep a 396XT on dispatch and a 396T for all other things,
the old street crimes now star units REALLY like to chit chat about what is and has happened and really fills in the blanks.
mjdewey
Bluffton, Indiana
In Indiana there is a fair amount of traffic on the 8 Tac channels. Many fire departments use them for on scene communications. Law Enforcement uses for tactical and chat. The state highway uses them for traffic control when they are flaggong.
chief21
Summer - western NC; Winter - Tampa Bay FL
Interop activity seems to vary significantly, depending on local capabilities and arrangements. Most locations tend to structure their comm systems to adequately meet their day-to-day requirements and interop frequencies are often needed only in extraordinary circumstances. Unfortunately, however, training in the proper use of these frequencies is often lacking (or inadequate), frequently minimizing their full potential.
MrColad
Bob Grove always suggested utilizing a separate bank in your scanner to search for hidden or hole frequencies. Nowadays I would use a separate scanner with recording and logging capabilities for NIFOG and Interop from the RR Wiki.
poltergeisty
Truth is a force of nature
RLG, Fly heading 053, intercept 315 DVV
Yes, I do. Here in northern Colorado I often hear mutual aid communications between cities with adjacent jurisdictions. Now there are also MAC (Mutual Aid Channels) as well which I guess are state-wide, but I don't recall hearing anything on those. But it would be a good idea to have those talk groups programmed should the proverbial :poop: hit the fan. I think it's safe to say that if you're hearing communications on a state-wide MAC channel then something is pretty big. Like 9/11 big.
bryan_herbert
Las Vegas, NV. DM26jc
With todays memory avail, in a basic radio, who needs extra now [Yes, some of us do]
The more you scan, the more you miss.
Its bad enough the processors in scanners are so slow, many areas, like Las Vegas, now have to contend with really large trunked radio systems.
Trunked systems pause the scanner long enough to search through all radio sites and talkgroups. If the trunked system is huge, like the Nevada Statewide Radio System (NSRS) or Southern Nevada Area Comm Council (SNACC), each of those systems can take a full minute to scan with a BCD436HP. A lot can happen in those two minutes. Now factor in all of the casinos and resorts you might want to listen to that have gone to trunking, thats another minute or two. Want to listen to Nellis AFB? Creech and NNSS are also on that system, thats another minute.
These things add up. Im currently running 3 scanners and its no where near enough to scan Las Vegas or the neighboring communities Boulder City, Henderson, and Lake Mead.
ILjim
Cook Co, IL
Here in the Chicago area, the Nationwide interop frequencies are very quiet. The only channels where I've heard activity in are U-TALK/TAC. In Illinois, VLAW31 is our statewide law enforcement freq and is used by State Police to put out flash messages about DUI's, armed robberies, etc to other agencies. Several of the VFIRE frequencies are used statewide as fireground channels.
